The cycling is related to physics, different ambient temperatures will make it perform differently, over time. What matters is the output temp, (and the pressures).
assuming you have ck'd the water collection bucket full switch for proper seating , im sorry to say that short cycling on compressors are a sure sign of low gas pressure , and no its not easy to add more
Your compressor has a direct short there is nothing that can be done just replace dehumidifier. If you replace compressor it will exceed cost of new unit. If this helps you please rate me and do a testimonial.
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space. If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem: Low refrigerant charge Bad compressor capacitor Bad compressor overload Plugged capillary tube or broken expansion valve are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Hi, There are many reasons why a dehumidifier will not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
I had this problem years ago when I lived in a more humid area, but I don't remember the exact details. I figured out that a switch was turning off the compressor. It may have been a heat sensitive switch, operated by a bi-metal actuator, and I either adjusted it someway, bending perhaps, or bypassed the switch. Sorry my memory is so hazy.
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
4 - Wired wrong
If the coil is freezing up and the compressor is short cycling,there must be a low pressure switch opening, do to either, low on charge or not enough air across the coil.
