Take it !!! the link of firmware drivers utilities and firmware
Here is the two different Firmware for SONY DRU-840A
Click the link and download
http://codeguys.rpc1.org/firmwares/sony/dvdrw/840A.SS01.patched-fb-fr.rar
http://codeguys.rpc1.org/firmwares/sony/dvdrw/stock/840A.SS01.stock.rar
And Here is the two Different Firmware Flash Drivers Utilities Link
http://www.samsungodd.com/KorLib/File/tsdnwin.exe
http://www.samsungodd.com/KorLib/File/sfdnwin.exe
Enjoy
you will flash your DVD Drive. May be this will solve your problum enjoy
SOURCE: Burning Speed on DRU-840A Sony Burner
Ok, problem has been fixed. Search of forums solved the problem.
SP3 and Office 2007 were not the problem.
I had a bad disk a week ago. Apparently, Windows will change the setting of the drive from DMA to PIO. This slows the data transfer rate significantly.
I uninstalled both the secondary IDE controller and the dvd burner. After starting up the computer, DMA was enabled. Nero and my burner were back to normal. Disks burned in 6 minutes vs 40 minutes.
See http://forum.videohelp.com/topic187112.html for details on what to do.
There was some advice on how to change the setting from PIO back to DMA by going into the registry, but there is some risk in doing so. I found that uninstalling the IDE controller and burner worked without having to fool around with the registry.
SOURCE: adding another DVD RAM drive on gateway computer
I made one drive master, the other one like a slave
SOURCE: Sony DVD RW (Model DRU-840A) Drivers
Hi, here are the firmware/drivers/utilities to your sony dvd drive.
>>>>Link<<<<
Hope This Helps
Muzzi_123
SOURCE: Sony DVD RW (Model DRU-840A) Drivers not found on
ABDUAALH POST http://codeguys.rpc1.org/firmwares/sony/dvdrw/stock/840A.SS01.stock.rar
