An i have i river x20.The problem is ..i save some files from computer to i river.I river become bloched with the mesage internal fille sistem eror please format disc.The computer not recognize and i can't acces the device.Buton navigation its not lighting .How i resolve this problem? Best regards, Angelescu Cristian
SOURCE: Formatting the iriver x20
I think you need to have a Windows XP w/SP1 or later and USB 2.0 port to connect to. Any older operating system/Pc will not do. Once you make the connection, simply Right-Click on the new drive letter (PC would have created for the player) and click <Format> followed by <start> .
SOURCE: external memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
SOURCE: iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
SOURCE: iriver X20
can you connect it to your computer?
if so then format it then run iriver plus 3
plug it into the computer
then go to tools>Portable Device>Disk Initialization
if you cannot connect your x20 to your computer
there is a tutorial on the iriver support page saying you can format it by,
holding down menu butting and turning it on
but that didnt work for me..
otherwise, its stuffed..
if its stuffed, dont throw it away, ill buy it off you..
contact me if your interested, [email protected]
SOURCE: How many watts do you think the i river X20's
Hi there and welcome at Fixya, the support team (lfete)
normally the speakers are around 2,5 watt in those products
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
