I was using Audials to convert audio books when an error message popped up. It said disk space was low, but dummy me clicked "OK" before I wrote down the location. I am running XP. Any idea where Audials stores temp files? Is this a common problem? Any help would be greatly appreciated!
Adam
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY.
Hard
disk maintenance should be carried once a month to make your computer run
efficiently.
This
removes redundant and temporary files, recovers disk space and speed up hard
disk access.
Disk Cleanup should be done
first - Click My Computer - then right click on the C drive then click
Properties, then click Disk Cleanup - let it examine the C drive then it will
calculate the amount of disk space it will recover, tick all the boxes to
recover the maximum disk space and then Click OK and then Yes to perform
these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to
be Defrag. This process converts fragmented files
into continuous files and this speeds up disk access and makes the hard disk
not work as hard. Click on Start - All Programs - Accessories - System
Tools - Disk Defragmenter - click to highlight the C
drive and click Analyse - then click Defragment.
When this is completed
repeat these steps for the D Drive if you have a D drive.
Disk
Cleanup and Defrag can take a long time to complete,
especially if these tasks have not been for a long time.
Low memory problems could be low virtual (hard disk) memory. Hard disk maintenance will free up hard disk memory space. Hard
efficiently. This
disk access. Disk Cleanup should be done
these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to
drive and click Analyse - then click Defragment. When this is completed
repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if
Click the "Advanced" tab, and click the "Settings" button under Performance.
You will see Virtual Memory under there. Click the "Change" button, and switch to "Custom size".
Initial size: 500
Maximum size: 2096
Click the "Set" button, close everything out and restart the computer. You should notice a difference. If you have any questions, please feel free to comment! Please don't forget to vote! Happy Thanksgiving!
Acer partition thir drives as standard install.....open my computer and you should see a C drive and drive called data (probably E drive)...when the C drive is low on space windows doesn´t have enough room for a swap file and really slows up......move some of your less used files from My Documents to the Data drive by cuttting and pasting......Make sure you leave at least 700mb free on your C drive so windows can work normally
Also go into internet options in control panel in the general tab under browsing history click setting....where it says disk space to use lower the value to around 300mb....click ok and close window....this should free up a bit more disk space
low disk space because one of the drive is almost full it is having below 200MB space so this message will appear . i think so C drive is full just right click on the drive and make disk cleanup and in that select temporary internet files,temp files, recyclebin,compress old files and say ok it will remove all the files from u r computer which is not required finally space will get increased and message will not come
