You can contact Epiphone directly, but really the most comprehensive diagrams of generic wiring is found on the Seymour Duncan site, and i'm sure you will find what you need there.
That is near fatal... you might find a Luthier that could repair it. I have repaired three broken neck instruments myself, an acoustic bass, acoustic hollow body, and a banjo... it is NOT fun and requires great care. The strains on the neck from string tension cause a lot of force that tries to re-break the neck.
Most likely it is wired like most Gibsons. The volume knobs are the two at the neck end, the tones are the two nearest the rear. The lower two are volume and tone for the bridge pickup, the upper two are for neck pickup. Switch down is bridge or lead pickup, switch up is for neck or rythym pickup, and centre position is both pickups one, where all knobs can be used together.
This will help for starters:http://www.epiphone.com/images/EpiOwnrsManul.pdf This site has good info in the discussion:http://www.thefret.net/showthread.php?t=4728 There's info here too:http://epi.p3net.net/bbs/index.php.
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls: http://www.guitarelectronics.com/product/WDUHH3T2202
