Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Probably your power supply. They are pretty cheap to replace. If it's plugged into a power bar then try plugging it directly into a wall socket just to make sure it isn't your power supply.
Try removing all hard drives from the system to see if you can get it to boot up at least. If so, place one hard drive at a time in the system to see if you can get it to boot as well. It's possible one of your hard drives may be fried, or, you may just need to reformat the drive fully.
