The out tray elevation motor failure, did some leave a trash can or some boxes below the output tray and they hit them:(:(:(. STORE NOTHING UNDER THE OUTPUT TRAYS!!!!. Rear cover of the finisher need to be removed, then the elevation drive motor assy removed BE CARE FULL THE TRAYS WILL FALL HARD FAST, so you most now how to that correctly Recommend a Konica Minolta Tech come out or the motor is bad worse case the control board for the entire finisher is bad!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta Di3510...C0500 troubleshooting
We have a NEC IT3520 which is the same as the Minolta Di-3510. The tech rep mode described above does not work for this model, does the NEC model use a different code?
sir/mam First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
