Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Hope this helpout......
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
