Samsung NeXus 25 MP3 Player Logo
Posted on Jan 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i have a Samsung NEXUS S cellphone . i see a small black point on the LCD and after few days this black point expand and now is almost half of the LCD is covered by this black point and i can not use device at all. but touch screen is working and everything is fine, only a big black area is on top.
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Jan 11, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263281
Points
2023
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jan 29, 2008
SOURCE: No picture
try chicking the horizontal section or vedio section...
Anonymous
  • Posted on Sep 24, 2008
SOURCE: Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Anonymous
  • Posted on Oct 06, 2009
SOURCE: touch screen of samsung star doesn't work properly.
all u need to do is to improve ur calibration
go to
MENU>>SETTINGS>>PHONE SETTINGS>>CALIBRATION
improve ur calibration but prefer to tick with thum
Anonymous
  • 927 Answers
  • Posted on Jan 02, 2010
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Anonymous
  • 13 Answers
  • Posted on Jan 18, 2010
SOURCE: touch keypads do not work
yes...buy another touchpad...
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
1helpful
2answers
How do you repair a broken nexus 4 screen?
I had a problem with my nexus 4, it's touch screen stopped working one day. I was quite upset how to fix it. The guy in the market asked me to pay him 80$ along with new screen. But that was still too much. I went to aliexpress.com and ordered one LCD for my nexus 4 ... And though to know how to replace it..
Then this website helped me in a great way.
https://www.ifixit.com/Device/Nexus_4 .. BTW this website also helped me in replacing HDD in my Macbook pro.
.. And this was a great experience. for me...
I hope this would help you as well
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Some water leaked down the back of my 42'' lcd samsung and now half the screen is black , initially the screen was fine then i got 1 black line then 2 and so on untill half was solid black , will the...
Yes. There are small adhesive indicators which are placed inside of the television which change colors once exposed to water or high humidity. Normally from white to pink. Same goes for modern cell phones.
3answers
Sony Ericsson W8580i half screen is black HELP
First you have to put out the battery, second you put then both separetely into a box with rice; you must be sure that both be covered into the rice, leave them to 48 to 72 hrs. This should dry completely the cellphone, i hope this may help you
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
