Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
Posted on Aug 14, 2008
Need to know how to set the time and date on a Columbia CL5008 wristwatch.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
248
Points
CLick mode until you get to time
Hold set button until chime is displayed
Clcik mode again until 12 hr is displayed mode agiain to hr St/sp to to incresse time Reset to Decrease
mode to cycle thru
set to finish
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Cant set wrist watch
How do you set time and date on Columbia CL5037 watch?
no online manuals for these
mode is the starting place
till time and and date start flashing
not a good idea to push reset while setting this watch
leave you two other buttons to push
3helpful
2answers
Columbia CL-5009
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Can't set the time on the CL5008.
To set your Columbia-
Hold down the set button until the display flashes. You can then use the mode button to cycle through the display features and set them. Use the strt/stp and reset to adjust fields.
For owners manual you will need to contact Columbia.
Contact Columbia
Customer service (800) MA-Boyle cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800) 622-6953cb_transparent_r.gif
Mon - Fri, 6:00 a.m. - 6:00 p.m. PST
Customer service Canada cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800) 265-7067cb_transparent_r.gif
42helpful
2answers
Changing the time on my wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
42helpful
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
3helpful
3answers
Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
