Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
I've tried an adapter (2.5mm male to 3.5mm female) with a standard 3.5mm stereo cable going from the iPhone to the adapter, but that didn't work. My guess is I need an adapter that has a 4 conductor 2.5mm male end (3 black rings), but I don't want to go out and buy the wrong cable again.
    Master:
  • 412 Answers
Look for this on amazon. Yes, you need a 4-conductor male plug with a "Y" cable that has a mic jack and speaker/phones jack. Be sure it says it's iPhone compatible.
Posted on Jan 20, 2018
SOURCE:
How do i hook up auxillary chord to a denon avr-884
There are several "line" inputs that should work.you will need an adapter to go from 3/5mm [1/8" phone] to RCA Stereo. This can be a cable with Male 3.5 mm stereo on one end and two RCA male on the other, or a 3.5 M-M cable plus a 3.5 female to RCA male adapter. or a stereo M-M RCA cable with RCA F to 3.5 Male...
If you have easy access to the back panel, plug into and use the CD/Tape [IN]. Or you can simply plug the RCAs into the front L and R audio and use that input sans video.
Jan 03, 2015 | Denon Audio Players & Recorders
I need my IPod charger longer
I'm sure you coula buy a longer cable online or a female to famale adapter an a male USB to male to lighten. Do a online search for a longer IPOd cable try here:http://www.amazon.com/iPhone-Charge-Double-Length-Standard/dp/B0033BU0F8 If you find this helpful or a solution check the box.
Nov 08, 2012 | Cell Phones
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
How do i connect the following speakers to a tv?
Look for a headphone jack plugin on the TV, and if you have one then plug the speakers into that. Otherwise if you only have RCA audio jacks on the TV (red/white plug-ins), you'll need an RCA male/stereo female adapter. I did a quick search and found this one on Amazon for $1.49:
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
You could probably find one at Radioshack or a local electronics store otherwise.
Also, in case you need it, here's a link to the owner manual:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Sep 06, 2011 | JBL CREATURE II Computer Speakers
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Some weeks ago the sub stopped working. Thought dog had chewed the coaxial driver cable, but not shorted (now). Tried another sub w/o success.
Hi, I went to the Denon website and they have no documentation there for your receiver.
But do not frown, I have some good suggestions for you.
0 Don't beat the dog. After all, it's their job to chew things.
1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2
2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub.
Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub.
You will need the following adapters.
1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone).
2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks.
3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends.
1 and 2 above may be available as a single unit combined with each other.
Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends.
This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz.
I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. .
Then adjust the woofer volume control in a similar manner.
If it all works out, give the dog a treat and enjoy yourself.
I really hope this helps, I love my sub woofer as well.
Let me know how this turns out.
If you have any questions please post them on the site and I'll get back to you ASAP.
Best Regards,
Mark
Jan 22, 2011 | Denon AVR-3600
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Mark
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
166 people viewed this question
Top Polycom Lands Phones Experts
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
