Kenwood KDC-138 FM / AM Receiver Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased a new kenwood KDC-138 head unit as well as two car speakers. The speakers were able to be installed onto my 2000 mercury cougar but the head unit gave me some troubles. The wires on my new kenwood KDC-138 headunit do not comply with my 2000 mercury cougars old radio wiring. What do you propose i do?
Anonymous
Level 3:
President:
  • Master 676 Answers
  • Posted on May 17, 2011
Anonymous
Master
Level 3:
President:
Answers
676
Questions
Helped
287386
Points
2168
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
2helpful
2answers
Subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
19helpful
KENWOOD KDC-138 SET THE CLOCK
set the unit to standby and press and hold the select button.(the up,down,left, right button on the left of the cdplayer)
2answers
Kenwood KDC-138: Removed Old stereo, installed new KDC-138, I'm getting power to the plug that plugs into the back of the unit & fuse is good. I've tried pushing the reset button. Nothing comes up on...
do you have power at both supplys on the wire harness?( red and yellow) red wire will have power with the key on. Also make sure your ground is hooked up right.
I have a KDC-138/cr. I installed it fine and was adjusting the balance, turned the system back off and on and now I have no output to my speakers.
do you have an owners manual -- ? I have a copy of you need one.. just send me your email address and I will forward it to you
1helpful
CD won't eject
If it brand new take it back to were it ws purchased to have it replaced.
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
