Master
- Posted on May 16, 2011
Re: How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
- Press the Up or Down buttons to select the Date option in the Setup menu.
- Press the OK MENU button.
- Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
- Press the Up or Down button to enter the Set Date option.
- Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
- Press the Up or Down button to set the Date and Time digits.
- Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
- Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
