SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
SOURCE: hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
SOURCE: The entrance door handle on my coleman natache pop
I also have the same problem. The only way to get into the panel (without completely tearing it apart is to drill out the rivets across the top of the door. The reason the screw is turning is because inside it's held in place with a nut that is turning. You can get to those nuts once the top panel is removed. Can you do me a favor? Where did you find your replacement handle? I've been looking everywhere and it would be SO helpful to be pointed in the right direction!
