For the new replacement battery, you could go to www.batterybay.net . They have this battery. Search for GSC320. It is about USD 15.00. Check it out!! Hope this would help!!
Follow these steps :
1.
Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5
Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
SOURCE: Garmin c330 update
What are you trying to update, firmware or maps? Firmware updates ae free from Garmin. Just go to www.garmin.com and download the WebUpdater. If you are trying to update the maps, these are available for purchase in CD or SD card formats, also from Garmin or your local retailer. They should be approx. $70.
SOURCE: Can I change the voice on my gps?
You can change the voice and you can choose British English, Dansk, Deutsch, Espanol, Francais, Franais Canadien, Italiano, Nederlands, Nederlands/ Belgie, Norsk, Portugues, Suomi or Svenska. You turn on the Garmin and on the bottom press onto the tool ( looks like a wrench or something ) and it will bring you to a screen with several choices just click on language and it will then let you choose. We change them around for fun sometimes. Good Luck
SOURCE: host mode
on the main screen push the wrench>push system>goto gps mode>hit normal> change normal setting to GPS OFF now it will allow you to update. Whew that was a buggar to figure out!!!
SOURCE: garmin streetpilot c330 can't find satelite
The Garmin c330s will have trouble acquiring satellites as the batteries wear out, which usually happens around 15 mo. Batteries are soldered in, so replacement requires sending it in to Garmin. I've seen some reports from users who had this problem right out of the box or shortly after purchase.
You May try
No.1
You can try both a normal reset or a master reset and see if either one works for you.
The normal reset button is behind the front bezel. You access it by using your thumbnail under the top part of the bezel and carefully pull the bezel off. Once off you press the reset button on the right side of the front face labeled reset.
Option #2 - Master reset, will lose all data.
With the unit off, use a pencil eraser to depress the bottom right corner of the screen while turning the unit on. Once on, let go of the on button and keep the lower right screen depressed and answer yes to do you want to reset unit and lose all data. Once reset you must allow the unit 45 minutes of good reception to reload all satellite data, moon data, time, etc...
Sure this would help .
God Bless.
SOURCE: can i find my garmin if someone stole it out of my
not likely, unless you have the serial number. you can make a police report and if the item is pawned it will find its way back to you. back tracking a stolen gps will be impossible unless yu have a tracking devise installed on the gps.
Testimonial: "thanks for the help, ill keep you in mind if anything esle comes up."
