If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
Testimonial: "Thanks again for taking the time! Very helpful answer."
Thanks for this. Will keep in mind -- I didn't know that. However, the LG was still on warantee and in was the motherboard. Replaced for free... let's hope this one lasts longer than 5 months! Thanks again for the help,
Julie
No problem! I am here if it gives you any further trouble!
I have been looking for the answer as to why my lg tv would only blink and not turn on all weekend I happen to find your suggestion after much searching and yours was the solution to my problem! Thank you so much! I was just about to bring it in to get it repaired and they probably would have enjoyed charging me to just plug it in and see that it works!
