Epiphone Emperor Swingster WR Logo
Posted on May 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Epiphone Swingster, bought three months ago new. The overtones from below the harp (between the bridge and the tailpiece) are so loud, paricularly on the upper strings that they ruin any single string playing and are amplified by the pick ups causing loud atonal squeaks. The G and B strings also slip out of tune frequently.
rhodesworks
Level 3:
Top Expert:
  • Epiphone Master 3,159 Answers
  • Posted on Jan 02, 2015
rhodesworks
Epiphone Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561490
Points
331463
Insert a piece of foam behid the bridge to dampen the overtones. You may need new heads to help the tuning.
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Nov 15, 2008
SOURCE: strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Anonymous
  • 161 Answers
  • Posted on Mar 23, 2009
SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Value of kimble grand serial 383273
this is a musical instrument to entertainment the people The first stringed instrument was the harp, on which the strings are plucked. The harmonic curve caused by the varied speaking lengths of strings dictated the shape of the frame of the piano and broadly follows the shape of a harp.
The monochord is simply a sound box with a single string stretched over a movable bridge to the position required, which is determined by a scale marked by "0" on the surface. The bridge is moved to each marking to give you a new note. It was plucked, and would now be referred to as a tone metre.
Mar 01, 2015 • Grand Music
1helpful
Wire up a epiphone prophecy guitar
It gets a little involved, I would recommend a simple book from say amazon, or google basic guitar wiring. Take an extra couple minutes and apply aluminum foil or adhesive metal tape where you can inside any cavities, then ground it. You'll reduce hum. Use good shielded wire. Practice soldering techniques, a cold solder joint will make the whole project flop.
Banjo tuning and bridge placement
Assuming it's a 5 string banjo, the notes are low to high G(octave)DBGD. The bridge is placed by hitting the harmonic over the twelvth fret and then fretting that note. Move the bridge until those two notes are the same pitch. Generally the bridge ends up closer to the tailpiece than the middle.
Strings slide off the bridge when bending notes on epiphone swingster, is there an upgrade for the bridge
Most likely the slots in the saddle just need to be recut. Any local guitar shop can help you out.
String buzz on epiphone swingster
Could be the nut, neck adjustment, or bridge adjustment. Best to take it to a guitar shop to get it fixed.
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
My tkl hard case cannot fit my emperor swingster due to the wire tremolo, is there any easy solution or must i find a way to remove the tremolo every time?
Without removing the tremelo it just will not fit... consider if removing the trem each time will wear the threads and cause problems... best to find a case to fit if you can. Some guitars have trems that will fold down... probably none available for this model though...
4helpful
I am looking for a manual (if there is one) for the Epiphone Sheraton II. I need to know which knobs do what (and also the three way switch) on the guitar. The guitar came with no manual!!
Most likely it is wired like most Gibsons. The volume knobs are the two at the neck end, the tones are the two nearest the rear. The lower two are volume and tone for the bridge pickup, the upper two are for neck pickup. Switch down is bridge or lead pickup, switch up is for neck or rythym pickup, and centre position is both pickups one, where all knobs can be used together.
Minimal to no bridge
Sounds like you have some microphonic pickups. Only thing to do is replace them. This would be caused by the guitar being hit against something or being dropped.
Top Epiphone Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
tednugentlives
tednugentlives
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
