Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
Posted on May 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
Level 3:
  • Samsung Master 6,688 Answers
  • Posted on May 15, 2011
Cindy  Wells
Samsung Master
Level 3:
Answers
6688
Questions
0
Helped
3532728
Points
21745
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
How can solve in this problem
Dear
Go to TECH mode, doing......(pressing the following keys in serial within 3 secs.)
MENU,copies,<,>,menu,>.
next place a white A4 size paper on platen glass.press MENU scroll to display TESTING press OK, scroll to display SHADING ADJUST press OK . a print out will come.
This will display the status of CIS. if RESULT is OK in the print, Printed at bottom of the page, the printer may work but prepare for the scanner cable (black ribbon type,visible under the platen glass has to be replaced).
Thanks.
1helpful
How to scan document in samsung scx 4300
Instal the scanner driver to your computer,or browse on network for Wizzard scanner.
Samsung scx 4300 scanner error
samsung scx 4300 show that erroryou can replace chip or reset by printer reset software.we sale that software with price 14.1$,if you interested in my software,please send email via: [email protected] access website http://baotrihethong.net to buy software
2answers
I need an installation cd for scanner
http://www.samsung.com/us/support/downloads/SCX-4300 here is the driver section of scx-4300 click on driver page and you will see a scan driver download and install it
Samsung scx 4300 scanner error problem pl, send solution.
the printer is printing a job which is not given by me so how to clear its memory or how to change status
1helpful
Scanner error of samsung scx 4300
well please check the drivers are properly installed if drivers are installed then try to insert the usb cable in other ports
I have had a SS Scx 4300 for 6 months with a starter catridge, it gave a message "replace toner" and I got it refilled. after that, it worked normally for some days, but now I can't use scaning and copying...
Starter carts aren't the same as the ones you buy to replace them and there is a module in Samsung machines to check the toners. The scanner error is something else, not related to the toners. With Samsung you get one year warranty, and should have it checked.
How run scanner on SCX-4300
goto any software i.e. msword, pagemaker, photoshop
insert picture from scanners
or directly scan from loaded software from samsung driver cd
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
