Question about Makita Drills
How do you remove the clutch on a makita 8406 have split the body so far ..thanks
How is the clutch removed from the makita 8406 core drill
Posted on Feb 05, 2012
    New Friend:
  • 3 Answers
Most of them have a screw that is located inside the chuck part of the drill. open it all the way and look inside. may need a flashlight, but you should be able to get at the screw easily. make sure to use the right size screwdriver and plenty of pressure so that you don't strip the screw head.
Posted on Jul 20, 2013
SOURCE:
Makita core drill. I have the 8406 core drill and when drilling a hole today, the drill suddenly seemed to lose a lot of power, it turns but not delivering enough rpm's to have an effect on the brick! the...
Sounds like it got too hot and burned the motor up. Had this with a making grinder. They are a piece of junk anymore. Hope it's still unber warranty.
Dec 26, 2017 | Drills
1/2 inch makita drill , model # 6013BR . Problem ;;;; great deal of arcing and smoke from vicinity of brushes. Would like to attempt my own repairs but am unable to remove the motor because I can't figure...
Take digital pictures as you go. Get a parts list if you can as well.
There are some electronics cleaners special for sensitive electronics and motors.
Compressed dry air may help as well.
Most drills housings will require a long round shank tool. These tools are in the forms of philips or torx some even security torx depending on the Mfg.
Jan 16, 2011 | Makita & 1/2 Inch Drill
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Can't get clutch plate off of makita 340 dcs
you need a piston stop to stop the engine from rotating,then with a clutch tool you can spin off the clutch,most of them are left had thread.if you don't have a clutch tool you can use a hammer and punch on one of the main arms of the clutch itself.for a piston stop you can use a piece of 1/4"rope.put the piston at the bottom of the stroke and stuff the rope in the sparkplug hole,this stops the piston from reaching it's full stroke.
Oct 20, 2008 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
15,701 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
