I have the same problem. It is impossible to use the parallel port when the printer is in this condition so it is a ********* messageI have the same problem. It is impossible to use the parallel port when the printer is in this condition so it is a ********* message
AnonymousMar 19, 2014
i have downloaded the firmware how do i install it on the desktop pci have downloaded the firmware how do i install it on the desktop pc
AnonymousMar 27, 2014
"Downld file now RFU LOAD ERROR RESEND RFU OVER PARALLEL PORT"Downld file now RFU LOAD ERROR RESEND RFU OVER PARALLEL PORT
You can't post conmments that contain an email address.
Need further information as there are several ways this can go, some of which are fairly complicated. Does the screen state Download firmware over USB? or Resend over parallel port?
Post the exact message and I will see if I can find you the tech document that shows the steps needed, depending on what the screen says.
For whatever reason your printer is trying to do a firmware upgrade and it isn't working.
If this came out of the blue, you may have to replace the formatter.
RFU = remote firmware upgrade.
If you caused the problem while trying to upgrade the firmware, try it again
You need to resend the firmware. If you have a parallel port on your printer you can do it from there, just follow the instructions that come with the RFU download.
If you only have network and USB then you will need to follow the instructions that I wrote for solving this problem on another model of HP.
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
HP Jetdirect firmware images have an extension of *.dld while the printer firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
RFU LOAD ERROR
