Did a full restore on my acer 5580 evrything was ok then suddenly the start menu disappeared with a grey line and internet page comes and disappears in a moment....
If you mean the browser icons, menu line, etc., press the Alt key, click View, Toolbars, Menu, then click View again and get the other toolbars to show up.
F11 will toggle you in and out of full screen mode, which also hides toolbars.
If you have a different problem, please click the Comment link below and explain your problem better..
Try zooming your the Safari window (click the green button at the top left of the window's frame) or try putting Safari into full-screen mode (click arrow thingy at top right of window frame) to see if the text box reappears. You can switch in and out of full-screen mode by typing control-command-F.
If this doesn't do the trick, navigate to a SPECIFIC page in Google search (start at www.google.com), then open Safari Preferences, click the General tab, and click the "Set to current page" button.
Create the menu tab on your
homepage right click in the top toolbar you should see a number of toolbar
options select the menu tab which will add File Edit View Favorites Tools and
Help
Click on the tools at the
bottom of the drop down list will be internet options or
Click start control panel
internet options you will see a home page box To Create Page Tabs type
each adress on its own line
(type in google.com) or your preferred home page and browser
below that will be change
search defaults click on settings you will see all search Providers
Toolbar
extensions and Accelerators you have if don't need any of them you can disable
or remove them.
You may have Malware. Open Control Panel, Internet Options, General tab, enter http://www.google.com/, Apply. Open the Programs tab, open Manage Add-ons, Toolbars and Extentions, disable ALL toolbars, In Search Providers, Remove ALL except Google , check both boxes in the bottom left. Two Freeware programs. Run a Full Scan with MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ AND use CCLEANER to clean the junk from your machine : http://www.filehippo.com/download_ccleaner/
It seems to be an issue with the temporary internet files folder.
Please follow these steps
a. Create a new folder to store the files. For example, if you want to store the files in a folder named temp123 on drive D, create the following folderD:\Ietemp or create it under c.b.Start Internet Explorerc.On the View menu, click Internet Options.d.On the General tab, click Settingse.Click Move Folderf.Click the folder you created in Step ag.Click OK, click OK, and then click OK again.h.Restart your computer. Now, check your emails. I hope these would fix this problem.
restart u r laptop and press f8 button when u r laptop start in starting press f8 and then restore u r system and again install u r driver after uninstalling
