Question about Garden
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs, enabling choke does not change engine performance. Changed fuel filter, plugs and air filter when problem started late last year. Ran fine for a period of time and then problem started again.
  • Garden Master
  • 813 Answers
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Posted on Aug 12, 2017
SOURCE:
  • 78 Answers
SOURCE: Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Posted on Jun 30, 2009
  • 61 Answers
SOURCE: engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Posted on Sep 06, 2009
  • 79 Answers
SOURCE: 02 yamaha vstar 1100, ran fine. started it the
Sounds like it may be drawing air around the intake somewhere. Let it idle and spray around carefully with wd-40 until it speeds up. This will reveal the leak.
Posted on Oct 11, 2009
  • 5603 Answers
SOURCE: kohler 19 hp runs then backfires and stalls when heated up
Check that the keyway for the flywheel to the crankshaft hasn't sheared. This is a common problem that throws timing very far off causing backfire and no-starts.
Posted on Nov 02, 2009
huffman49
  • 235 Answers
SOURCE: MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Posted on Apr 10, 2010
It starts -but doesn`t stay running if I spray carb cleaner it runs as long as I spray ?
Fuel starvation, if the engine has a separate fuel pump, disconnect the hose from the outlet side of the pump, crank the engine, if there is a good flow of fuel then check the fuel solenoid if fitted in the base of the carb, there shoud be an audible click when the ignition switch is turn on, failing that you have dirt in the carb, so off with the carb and clean out the fuel jets.
Sep 13, 2018 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
My 23 hp kohler courage engine starts and runs for several seconds and stops. The gas is fresh, new plugs.gas filter. Fuel pump is working.The thing ran fine two weeks ago. Thanks, Mike
it sounds like the jet is dirty in the carburetor. Remove the float bowl and in the center there should be a jet that you can remove and clean. There are small holes on the side of it which you can clean with a thin piece of wire. Clean the center hole also.
Mar 25, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Kohler k582 runs poorly at operating speed. ok at idle. ambient temperature is 30 degrees.carb main fuel needle adjustment is ineffective. backfires with occasional black smoke. condition started as...
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Jan 13, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
160 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
