Step 1: A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately. Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning. http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Use a card holder to connect the memory card to the PC and if this is not detected check it out on another PC. If not detected then the card is defective. If not you can right click and format the card after removing all the files from the card.
If the card is not detected it is damaged and you can try if there is a free replacement from the dealer.
Please try your card into a card reader in a PC or laptop. If this detects in the laptop then your camera has the card contacts out of alignment. sometimes the contacts can shift off from the edge or can be broken. If this is opened the tips of contacts can be pulled up to contact with the sd card when pushed in so as to detect. If there is no detection in the PC then your card has a fault and it will good to contact Sandisk for support to recover your memory files.
Firstly check whether u have inserted memory card correctly . If that is correct then check whether the phone is detecting the card. I think blackberry has an option to check it .
If the phone is detecting the card then check for the free space it is showing on the card . If it is showing the correct space and not showing the contents then switch off and switch on the phone after removing the card .
If the phone is not detecting the card then check the card using a card reader there also if it not getting detected then you need to check the card whether it has some physical problems. If the card is getting detected on the card reader check your phone with some other card and even after that if the same situation exists then you can take your phone to a service center
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
your card is automatically locked and it is only unlock by using memory card unlocker device but it also format your mmc.other than this you have no choice to open memory card.yes you can use recovery software for recover your important files
See if the phone detects a different memory card. If it doesn't detect any cards at all, try to reset/update the phone firmware. If that doesn't work the card slot might be damaged, maybe dust and dirt?
