All manuals are free if they are available. Your make model seems incomplete, I see Euro-Pro and Shark in the results. The search query for this is just three words;
It could be one or more problems. The filter is likely clogged. It should be replaced at least once per year if you can find one. Clogged filters greatly reduce airflow which will cause dirt and debris to build up in other areas of the vacuum eventually causing it to have no suction. If you get the suction working make sure to install a new belt if using it on carpeted floors.
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
