Pioneer PD-R555RW CD Recorder Logo
Anonymous Posted on May 14, 2011
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on May 14, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764882
Points
24828
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
  • Anonymous May 14, 2011
    It keeps saying "No disk" when I hit record. This is just terrible. My songs for a wedding are trapped in the Boss BR-8. Any other thoughts? I'm using the same type of CD that I have always used in the recorder. Jen
    That's not what you said the first time.
    Humor it. Try a different type of disc. Or the drive is shot.
    Read this...
    http://www.repairfaq.org/sam/cdfaq.htm
    Have you thought about interfacing the mixing board to your PC for this emergency?
2answers
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
You can only use Music CD-R with the logo of Digital Audio, no regular CD-R for data will not work with any CD Recordable, it doesn't matter the brand of CDs. Remember that, I have a player like your and Sony, and that's the catch.
2answers
Disc does not spin
First do a lens celeanup, just in case.If it does not work It may be the motor. But before opening it I suggest to check if it is under guarantee.
tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 • Apple iPod touch
I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
2answers
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
2answers
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
3answers
Pioneer PDR-609 CD Recorder. - My recorder frequently fails in the middle of a recording -it stops recording and says 'check disk' in the display. I have several different types of disc (I usually use TDK...
I don't have a stand-alone cd recorder but like many people I have burned discs on the computer and had many disappointments. While some disc drives are clearly better than others, for no apparent reason, there does seem to be more reject discs with some software than others.
Particularly disappointing is the Nero burning software that performs well when it is first installed but seems to deteriorate fairly quickly with every computer restart. I know nothing about such things so I am only guessing the cause might be that Nero displaces some Windows components and Windows seems to try repairing itself when booting.
Like most things these days, especially digital things, your cd recorder is in fact a computer that depends entirely on the software loaded into it, software that could degrade or become corrupted over time.
While it is possible the disc drive (laser perhaps) has become less potent it wouldn't be unreasonable to suspect the software and I suggest you contact Panasonic.
It is probable, like many things requiring software, early versions were found to have problems and would be periodically updated.
Pioneer PDR-W839 Disc Changer Jammed
look for a small pinhole and insert a pin while powered up to reset the device
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
