Note that you have to do this with the remote control, there arent any buttons that will work on the front of the unit. If you don't have the remote (like myself) and you have an Android phone with a remote IR blaster installed, I was able to use the app ZappIR. In the app you select the model and it supplies you with a ton of buttons. I randomly pressed the buttons until "sub off" displayed, the rotated the multi jog selector on the unit itself till "sub on" appeared.
No. It's Line Level and thus would not be involved in a protection circuit.
Read the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-D57-Receivers-manual/id/1076dj788/t/2/
Page 5
Thanks, Ryan. I, myself, knew of no way to turn on or off on the sub until you told us..."manual select on remote and use the multi-jog." And then, "BOOM!" Talk about bass. Appreciate it, Ryan
I have the same problem. I can connect the subwoofer with speaker wires to the amp output and it works! However, finding an unused output is a problem. I need help from this step onward...
Hit the 'manual select' button on the remote and make sure the subwoofer is turned 'on'.
