Our griddle stopped working. Removed the griddle plate. When the knob is turned on the light goes on but there is no gas coming from the vents. All the other burners work normally.
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Since the pilot light stays on, and the main burner comes on momentarily, then goes out. This mean to say that the gas supply is not steady, it also goes off. You got to get your gas valve repaired or replaced to get it working.
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
I'll give this a go!
With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically.
However, you are having to try and manually keep the gas going for a good five minutes.
I would think that there is either a problem with the thermocouple or the gas control valve!
Tony
www.birminghamelectricsltd.com
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven
work fine. The griddle just stopped working, no spark. Turning on the
griddle control, the gas valve opens(hear it), gas flows (smell it),
but the ignitor will not spark (no loud or faint spark that I can
hear). I got a replacement ignition device (mount at the burner)
thinking it might be the problem, but still no spark. I checked the AC
voltage at the terminal and measured 39 VAC between the terminal and
ground. Not sure if that is the correct voltage. Any insights or advice
would be great.
