My nokia 7210 supernov had avirus i need to format it but it says the security code i type the default code 12345 but i didn't yes how to fromat nokia 7210 supernova withou using security code
You can unlock your Nokia 7210 Supernova using Master reset codes!!!There are many online sites that offer these codes!! Personally i would suggest unlocking4free.com , here you can get reliable codes for free of cost!!!
The default code for a Nokia device is 12345 and if that does not work try this for Nokia *#7328748263373738# Resets the security code to default(ie,12345)
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site Unlock-free.com/nokia/nokia-7210.html and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. OR: Reset factory setting with nokia flasher box. Thanks
just remove your MMC n just type *#7370# n will ask u the security code.type it out (default code is 12345 ) NOTE: battery must b full, else if format is disrupted by low batt, consequences will b disastrous I heard the code *#7780# works too, pretty much the same i think.
but back up everything before doing this onto ur computer or MMC.. dont forget to rate me.. thank you sir
