THE AC UNIT KEEPS LEAKING INTO THE CAMPER (EVEN WITH NO RAIN) I ALREADY HAD THE SEAL REPLACED. IS THERE A DRAIN FOR THE PAN THAT COULD BE POSSIBLY PLUGGED? IF SO, HOW DIFFICULT IS THE FIX. THANK YOU.
MARK
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
how to fix a inside roof on a 1991 coleman popup camper
