Nintendo DS Lite Console Logo
Anonymous Posted on May 14, 2011
I need to know how to get wi-fi on my ds - Nintendo DS Lite Console
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 96 Answers
  • Posted on May 14, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
96
Questions
0
Helped
20191
Points
295
The DS has a WiFI chip built in but its mainly for connecting one DS to another DS. Try Pictochat with another DS user. You can use the WII with your Wifi but you'll need an R4 or Evolution card
which aren't legal to sell in some countries. Once you have one of these you can use different
homebrew apps to access the net
see:
http://en.wikipedia.org/wiki/Nintendo_DS_homebrew
for more info
  • Anonymous May 14, 2011
    If you want to play with Nintiendo homebrew also checkout No$gba, and Desume
Where do i go to get a wifi conection
To conect to wifi, you'd need to buy a WI-FI USB connecter. They can be found at most video game stores for $37.00 (varies on location) They get plugged into your USB port on your computer, then they enable you to connect to wifi . If you have a Laptop the USB port should be found on the side.
If you just need more information off of what I've given you, read the bottom of my post for a recommended website for Wi-Fi.
When you get a USB connecter:
On your DS:
Once you have it plugged in, turn on your DS with a game that is compatible with Wi-Fi. In the game there should be a place where it allows you to adjust your Wi-Fi settings.
When you select that, two options should appear, tap on the one that is labled "Nintendo Wi-Fi Connection Settings" You'll see four options to chose from, you want to tap on the one near the bottom of the screen, it's shown as "Connect To Your Wi-Fi USB Connecter." The next screen will say for you to install your Wi-Fi connecter software to your computer
On your computer:(you must have internet connection on the computer)
Close your DS for now and turn your attention to your computer, insert the USB into the the USB port on your computer. The picture that is next to the port will look like this:
Install the software first, then a window will appear after the installation. Ignore it for now, and look back to your DS.
On your DS:
It should still be on the same screen you left it on unless your battery is dead (not recommended to conect to wi-fi with low power )
Tap "Ok" on your DS, It'll then launch a test connection. Look back at your computer screen now.
On your computer:
The box I told you to leave alone before will still be on, and now it should have your DS name inside it. Your DS name is what you entered your name as on your DS configuration settings.
Click on your DS name and select the option allow access. You can either allow or deny anyone access to connect on wi-fi through your USB.
On your DS:
Now that you have allowed access to your self on the computer, you can get back to your game and tap on "connect to Wi-Fi" this time instead of tapping "test connection." You'll then get a friend code that will allow you to interact with others who have connected with the same game.
Notes: For more about getting started,connected, and swapping friend codes, view this site: http://www.nintendowifi.com/global/AboutWIFI_DS.jsp
Also, if you've ever heard of a Wi-Fi hotspot, that just means you have to take your own computer or laptop with Your own Wi-Fi USB connecter to the certain area for free Internet service. This only means public areas, like at Starbucks or Panera Bread Compay, but then if you're doing this at a friends house then you just need to get your self registered access on their USB.
1helpful
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
How do i install wi-fi on my ds lite? and is there wi-fi in Nigeria(lagos)
you need wireless internet, if you have wireless internet and it is still not working, there are generaly these reasons:
- a wep key, you can get it from your wireless router.
-there is other electrical interferience with another electrical object and the ds.
-your internet connection security is too high for the ds, if so lower it by going to control settings and lowering the security there, if u dont want to lower security get a nintendo wifi usb which lets you make a wireless acsess point for the ds without having to lower security on the computer after that you need to follow the instruction on the screen.
If you dont have wireless internet you have to buy a wireless router, or go with the wifi usb first hand even without the wireless internet and about wi-fi in Nigeria(Logos) i realy dont know if it is but you can test if you have all the equipment and it's easy just search.
How do you activate nintendo wi-fi connection
The DS Lite doesn't have built in Wi-Fi. Some games have Wi-Fi built into them, and they have to be activated from within the game itself.
The DSi and newer have built in Wi-Fi. www.nintendo.com has a guide on how to activate it on them.
Good luck,
Mark
1helpful
I,m trying to connect to nintendo wi-fi. but I can't fill in the form. What can I do?
you need to get to a spot where you know theres wi-fi and you can connect before you hit your file to resume playing on ds...you can check your coonnection
My nintendo ds dos not connect to Wi-Fi what should i do it will not connect to my D-link any more
either the wi-fi signal is low or you need to update the system if the system needs an update you cannot connect to a wi-fi signal i hope this helps good luck.
My ds cant find my wi-fi adapter
dont worry ppl i fixed it, i found out that my internet connction that was going through the W-Fi adatper, wasnt accepting echo requests. but it works now.
2answers
I GO TO NINTENDO WIFI.COM AND I DON'T KNOW WHAT TO CLICK ON TO GET MY DS LITE'S WIRELESS CONNECTION CODE FOR WIFI PLAY ON POKE'MON PEARL VERSION!!!!
Usually when you connect to Wifi, you automatically get a connection code. You do not usually need a code to connect... Something may be wrong with your DS's connection.
Im trying to get my ds online to my router
Hello irishguyroy, I Have a DS and It Is Connected To Wi-Fi. The Only Way You Can Connect to Wi-Fi is through a game with wi-fi. if you need more help, leave me a comment on my help site:
www.rosebetts-at-fixya.piczo.com
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
