SOURCE: Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
SOURCE: Samsung SyncMaster [Monitor] (22.0 - I need best settings
hi , any has got the drivers for this monitor , kindly let me know to download it . regrads
SOURCE: schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
