This faucet has two O rings under the handle..Turn the water off at the valves under the sink, there is an allen wrench screw at the back of the handle. Loosen the allen screw, take the handle off. Then you will have to unscrew the faucet head from the base. (counter clockwise). Once the head is off you should see two O rings you will have to change them both. Also, inspect the O ring on the head itself. You should go ahead and change them all. Hope this works for you.
