Question about NComputing L230 Network Terminal
NComputing L230 won't connect to host
The host Console says Waiting for connection... When you click Connect on the client, it just says Cannot connect to server. No firewall on server, uninstalled & reinstalled Console, no luck. Any ideas what to look for?
    New Friend:
Sir when i am connecting L230 WITH my Pc Lan port show no connection but Pc Lan port is working with other device plz resolve the problem
Posted on Sep 19, 2018
    New Friend:
M -series NComputing has I can not connect to the host . I've checked the IP address for the host , I also had to disable firewall and anti- virus . but nonetheless " can not connect to host " I have tried to uninstall and reinstall but nonetheless . about how to fix it ?
Posted on Jun 25, 2015
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Posted on Dec 30, 2008
6ya staff
SOURCE:
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
It says :"you have been disconnected from online servers"
There can be particular issues related
to playing through a router or firewall,
including sharing your internet
connection via another PC. In order to
join or host a Conflict: Global Storm
game from behind a firewall you must
open the following ports (inbound and
outbound):
UDP ports 4658, 6500, 10010,
13139, 27900
TCP ports 4658, 6667, 28910,
29900, 29901, 29920
To host a game from behind a router
with NAT (Network Address
Translation), or a firewall, you will
need to enable ‘port forwarding’ on
the following ports to route data to the
IP address of your PC;
TCP port 4658
If you continue to have problems
connecting to servers or creating
them, try bypassing your router or
firewall by connecting your PC directly
to your broadband connection.
Do not use ALT+TAB and do not enter Windows when multiplayer is running. It will kill the connection to GameSpy servers which are needed for connecting to any internet server.
Apr 26, 2009 | Eidos Interactive Conflict: Global Storm
Hello
SOCKS is an Internet protocol that facilitates the routing of network packets between client-server applications via a proxy server. SOCKS performs at Layer 5 of the OSI model - the Session Layer (an intermediate layer between the presentation layer and the transport layer).
Clients behind a firewall may connect to a SOCKS proxy server in order to access external services through the firewall. Such a proxy server controls the eligibility of the client to access the external server and, if the client has eligibility, passes the request on to the server. SOCKS can also be used in the opposite way, allowing the clients outside the firewall ("exterior clients") to connect to servers inside the firewall (internal servers).
SOCKS software
* Kernel SOCKS Bouncer ksb26 (Kernel Socks Bouncer) is a Linux Kernel 2.6.x Loadable Kernel Module that redirects TCP connection (to user-defined target hosts) through socks 4/5 chains.
* SS5 Socks Server is an open-source SOCKS4/SOCKS5 server.
* Dante is an open-source SOCKS4/SOCKS5 implementation with commercial support developed by Inferno Nettverk A/S.
* OpenSSH allows dynamic creation of tunnels, specified via a subset of the SOCKS protocol, supporting the CONNECT command.
* WinSocks is a light-weight SOCKS4/SOCKS5 server developed by Proxy Labs.
* SOcat Multipurpose relay (SOcket CAT): includes socks4, and socks4a functionality (Linux / Mac)
* FreeCap Socksifyer for Windows, any App can run its network traffic transparently via a SOCKS or HTTP proxy.
* Simple Socks Server for Perl - SSS is a Simple SOCKS Server written in perl that implements the SOCKS v5 protocol.
* Sun Java System Web Proxy Server is a caching proxy server running on Solaris, Linux and Windows servers that supports HTtp://S, NSAPI I/O filters, dynamic reconfiguration, SOCKSv5 and reverse proxy.
* BarracudaDrive Web Server - commercial SOCKS HTTP HTTPS tunnel/server, available for Windows, embedded Linux and Mac OS X (PowerPC)
* DeleGate is a multi-purpose application level gateway and proxy server which runs on multiple platforms. Beside SOCKS it also supports HTTP(S), FTP, NNTP, SMTP, POP, IMAP, LDAP, Telnet, DNS and many more.
Jan 05, 2009 | Computers & Internet
Managment
You can connect to the FW appliance:
1. trough the cosole port
2. through the inside ethernet port
Either way you will need to get the random key from the LCD on the front.
1. requires learning the console menu
2. requires a client application installed on a Windows or Linux Host
Feb 26, 2008 | Symantec Axent VelociRaptor 1000...
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
NComputing L230 Network Terminal Logo
8,247 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
john cordey
john cordey
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
