Hi
With sorrow, the screen have problems
What recently happened before those lines appear?
You can knock ( softly ) on the back of the screen around the lines, and see what happens
Please tell us your results
Good Luck
I am afraid the problem is most likely NOT the led/lcd cable, but the panel itself will need replacing
SOURCE: vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
I TRIED KNOCKING AND SLIGHT TWISTING AND THE LINES SEEM TO BE ON AN OFF.
