Computers & Internet Logo
Posted on May 13, 2011
Free Manual for Android OS 2.2 (Kernel 2.6.32) Build Number V1.2.3
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2204
Points
7
My tablet pc can not boot
Juan
Level 1:
  • Posted on Nov 15, 2012
Juan
Contributor
Level 1:
Answers
Questions
0
Helped
2204
Points
0
Como descargo el os de android mi correo es [email protected]
How do i root my samsung sch-s736c by android
If you are lucky enough to have not updated and are still on the VRUAMDK Build number then here is the root method (source & credit given to: http://forum.xda-developers.com/showthread.php?t=2290798):
STEP 1: Go to the source link above and download the five items in the first step, Samsung Official USB Drivers, ODIN v3.07, VRUAMD2 Prerelease Kernel, Stock VRUAMDK Kernel for your phone, and Motochopper Root Exploit Tool.
STEP 2: Boot your phone into ODIN mode.
STEP 3: Flash the VRUAMD2 Prerelease Kernel using ODIN v3.07 in PDA section only. Boot back into Android and verify that the flash was successful.
STEP 4: Follow Settings -> More -> About phone -> tap "Build number" 7 to unlock Developer options and verify in there that you have "USB debugging" checked and "Verify apps via USB" unchecked. Verify in Security setting on your device that you have "Unknown sources" checked and "Verify apps" unchecked
STEP 5: Connect your phone to your computer and open "Run.bat" file from the location you have extracted motochopper to. You will see a message on the phone asking you to accept the new computer connection (select to always allow and select OK).
STEP 6: After motochopper runs and your phone reboots on its own, check if SuperSU has any update in the Play Store. Open SuperSU app and let the binary update itself to the latest VERY IMPORTANT OR YOU WILL LOSE ROOT ON STEP 4. Now you can open a root application and verify that is able to access root properly.
STEP 7: Now to restore the stock kernel you need to boot your phone into ODIN mode (how-to link above).
STEP 8: Flash the Stock VRUAMDK Kernel using ODIN v3.07 in PDA section only (follow same link in step 3 for a how-to).
STEP 9: Boot back to Android and verifying everything is still working and kernel has flashed successfully. You should now be fully rooted and on the fully stock original firmware that came on your device.
To restore a custom recovery (optional), follow Step 5 on the source link.
Some of my pre installed apps were force stopped under the applications manager and now I don't have the option to start them back up because my phone doesn't show that option. I would rather not do a...
just click on the app and it should start. now go back into application manager, it should now give you the option to force stop.
so all you have to do is open the app you cant to restart and thats it.
Jul 24, 2014 • Cell Phones
M android tablet 7inch os 2.2 kernel 2.6.32 build number v1.3.1 is stuck on android logo how can i factory reset it
Hello Dear Friend::":
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234,1122 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 22, 2013 • Cell Phones
5helpful
2answers
Process com.wmt.launcher for program start-up screen has stopped unexpectedly. attempt again
the application wmtlancher (process com.wmt.lancher) has stopped unexpectedly.
4helpful
When i turn my android tablet on it just showsthe greenman who is stationary it also tells me os 2.2 kernel 2.6.32 build number v 1.2.3 the screen as stopped and i can`t do anything on it.
Hi there
There is a reset hole. Please insert an unfolded paper clip and push the button for about 10 seconds.
Let me know what happens.
Thank you for using Fixya!
Grand Canyon Tech
Grand Canyon Tech
