The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
3) Third reason maybe your flash drive have problem many time it has been found that Flash drive have hardware issue because of which it is not allowing to format.
Regards,
JJ
Hi sampagac ,
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Hope this helps ...:) your feedback would be appreciated.
It look like your flash drive(fd) is infected by something. Are you try scan with up to date antivirus?
try scan and format again .
if still face same problem?
TRY FORMAT USING M-DOS:
Format/x G:
PROBLEM AGAIN?
TRY THIS:
