SOURCE: My epic 425 mx treadmill doesn't fold properly.
1. Hold the upper end of the treadmill with your right hand
as shown. Using your left hand, pull the latch knob to the
left and hold it. Pivot the treadmill down until the frame is
past the latch pin. Slowly release the latch knob
I will strong that you see your owner manual. If you do not have manual.
here is the web page for you download free right now:
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=EPTL88105&modelName=EPIC+425+MX+
sincerely.Good luck.
SOURCE: I can't fold my treadmill
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
SOURCE: my treadmill turns on, but doesn't start
1) LUBE the deck belt, this happen by lack of maintenance, maybe you have deck worn.
2) LUBE the rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
