Televison & Video Logo
Posted on May 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to turn the close caption feature off and close the black screen. Do not have a Up button nor an exit button. How can I toggle this feature off?
Anonymous
Level 3:
Top Expert:
  • JVC Master 14,553 Answers
  • Posted on May 13, 2011
Anonymous
JVC Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716013
Points
48227
Just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
Tv comes on then black square pops on screen
Hello
Closed caption option is "ON". Just turn it 'OFF' If the remote control of your tV has a "CC" button. press it once. If it has't that button, you have to enter its Menu option, surf through, and come to closed caption function window, and select the closed caption OFF.
1helpful
We have a JVC model AV-32432 and we have a black square on screen
it's one of the closed-caption options. get into the menu and remove the cc.
5helpful
TV has a black square box blocking out the channel
this is probably the closed captioning option, go into the menu and turn off closed captioning, its probably on text....Hopefully this helps
2helpful
I have a JVC model 36D501 TV and I have a large black box appearing on the screen....I think it's a pip problem, but I can't get pip to disengage....help
It is probably the closed captions on text mode.
look on the remote for a CC button or use the user menu to disengage the closed caption.
Mike
6helpful
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
4helpful
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2helpful
2answers
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
How do i get out of lock on my tv
This set has a front panel MENU button which is good, since most universal remotes don't seem to work the TV menu.
Use the menu button to get to the closed-caption setup and make sure it is turned off. The black square is because the captioning is set for text mode. That part of the screen is being blacked out so the text (which isn't there) can be displayed.
In mute operation: Want to read what is being said
Hi Wylie77,
The feature you are looking for would is called CC or Closed Captioning. Per your owners manual you would press the menu button, then move up and down to select "CLOSED CAPTION" from the list. Then to edit the feature press left or right. Select CAPTION to on. The manual lists four different types of captioning (C1-C4) and also four different types of "Text" (T1-T4). Usually one of the caption listings will display only when the mute is selected...its just not very clear which one exactly will do it.
One word of warning, you would not want to activate the Text features. This will sometimes have a large black box appear in the middle of your screen providing other information.
Unfortunately JVC does not have a link to your manual on their website, but the manual should be able to be found by entering JVC AV-32120 Manual in a search engine. I would check a few of the results because some maybe free others may ask for a "nominal" fee.
Hope this helps.
Jon
Go Ahead. Use Us.
Black square
Hello greeny11
get your remote and press menu and look for close caption. Turn off clase caption and this will go away. If you need close caption , set it to CC1
best regards
circuitcity
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
