This may be caused by a burnt heater relay in the control panel. The water just doesn't get hot enough by itself, cycles take longer and dishes don't get as clean. This happened to me and I just replaced the control panel. If I were better with a soldering iron, I would have just replaced the relay, a lot cheaper too.
Most bosch dishwashers have a filter that can be removed and cleaned at the bottom of the tub check filter to see if it is dirty. if the filter is clean make sure your water is hot enough min 120 degrees at faucet may want to run hot water at sink before starting dishwasher
