I have a bosch axxis 2060 and i have a problem
when the washer finished the upper led is blinking and the door couldnt open. i also notice that the water in the washer didnt flush
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like. I did a quick search and it looks like you're looking for part number 1046685 .
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
