Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Carol Jakubisin Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The menu screen is on and we can not take pictures, we can not get out of that setting
Anonymous
Level 2:
Sergeant:
  • Expert 304 Answers
  • Posted on May 12, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
304
Questions
0
Helped
52263
Points
858
Hi, If it won't let you quit out of the menu screen I'd suggest turning the camera off then on, if that doesn't work take the battery out for a couple of minute and that should do the trick.
Lg 55lf5700 dark sceen
The screen is not working anymore and the built in light inside of the screen is burning out and the screen needs to be replace on the The TV's screen is either Dark or blurry picture is most often caused by the result of picture setting. If the screen is still dark after turning off Energy Saving, click Back on your TV's remote to return to the Picture menu. From the Picture menu, select Picture Mode Settings. Select vivid for the highest brightness, and most vivid colors.
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
I have a JVC I'ART 27" TV. Model # AV 27F485. My screen is in wide screen. When I play video games or movies everything on each side of the screen is past view. I went to the menu but can't find out...
Hello
Hit the "Menu" button surf through and enter "Picture settings' screen. There you can see various picture adjustments options. Just press "0" [zero] button on your remote, will set all the picture settings factory levels, and will solve your probelm. OK.
How doi reset the picture after replacing the bulb and housing
It is not required to set the Picture after replacing the Lamp and Housing. To change the Picture Settings press the MENU button on the Remote, highlight PICTURE and press OK. There you'll get the option to select Picture Preset Mode, Picture Settings, Screen Format, Advanced Picture and Screen Adjust mode. You can customize the settings by selecting the each Picture Menu options.
Click here to download the manual of the TV. View page # 39 for the instructions to change the Picture Menu.
Good Luck!
Thanks for using FixYa
2helpful
Sanyo CP29YS2B - Picture has zoomed in/enlarged
My Sanyo CP29YS2B - all of a sudden picture has changed - it now looks like it is in a zoom mode - large parts of the eterior of pictures and menu settings do not appear on screen. Using menu does not offer any solutions
No picture
The main problem is from theTV menu.I would recommend you press,menu,then settings,then display settings,and last tv screen. After, you'll get options on how you want to make your screen look like.Example:wide screen, Automatic, etc.
2helpful
2answers
How do I make my tv pic full screen? My tv programs are shrunken to small screen...
GO TO MENU ON UR REMOTE CONTROL AND SELECT PICTURE SETTING .....
THIS OPTION WILL GIVE U THE PICTURE SIZE ON UR SCREEN U LIKE TO SEE....REMEMBER NOT ALL PROGRAMS ON TV ARE IN FULL SCREEN MOODE
3helpful
2answers
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
6helpful
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
