Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Hi
It may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
