Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, i have printer@scaner epson tx100. but i cant make the scaner work. i tried a lot of times to load the drivers, my printer is working, but scaner dosent! my computer do not recognise it!
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on May 12, 2011
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340413
Points
4062
Lapinskyi,
If you are loadiing them from a disk I have a tip at http://www.fixya.com/support/r7723090-setup_all_in_one_printer_scan_computer which tells how to do that or better yet how to download and install the latest drivers from the internet.
Thanks for using FixYa and for the great rating.
hardrocko
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Error for my Epson TX100 printer " parts has
Part unavilable. Please replace the printer
I lost my disc to install epson tx100 in my laptop. how can i install it?
Here is the link for the Epson TX100 printer driver:
https://www.yousendit.com/download/MzZGOGNRTXZTRTd2Wmc9PQ
Here is the link for the Epson TX100 scanner driver and Epson Scan utility:
https://www.yousendit.com/download/MzZGOGNTTk16NE5FQlE9PQ
2answers
Does the Epson tx100 actualkly have a scan function? I cannot find a button or way of working it.
Hello how are you.
Yes it have scanner on your printer but to use you need to do from your pc and go to users options and there you can see to use.
Hope this good for you thank you.
Usai
Why my tx100 printer can't work with vista
ISSUE : Epson Stylus TX100 is not working with VISTA Computer
Environment :
Printer : Epson Stylus TX100
Computer Operating system : VISTA
Analysis : According my understanding your printer use to work with different operating system like XP Home /Prof. etc But it is not working with VISTA
SOLUTION :
Cause of your problem might be : Software issue
To get the print out of printer your computer need to have a driver software on it. You can check the compatibility information written on the CD / DISK itself
Else you can also download the Compatible drivers from the following link of EPSON
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1373
or you can simply open www.epson.com
and click on Drivers and Support and select the printer -- you can easily download the drivers ...
I Hope it will solve your issue
1helpful
All in one epson stylus tx100 installer
You can find the necessary drivers that you'll need for the TX100 on Epson's website. I've included the link for you below. Hope it helps!
TX100
4helpful
3answers
Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
