Microsoft Windows XP Home Edition Service Pack 3  Full Version OEM for PC  Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having lost everything on my computer, I purchased Toshibo laptop, installed with Windows 7 family edition . My Hp desktop printer, and everything else worked with windows XP. I am unable to install a flash. I want to install windows XP so I can play my word games, etc. Where can I purchase an installation CD to install Windows XP, either new or second hand. Please advise. [email protected]
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 218 Answers
  • Posted on May 12, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
218
Questions
0
Helped
41935
Points
680
You could upgrade to windows 7 ultimate as this has a xp compatability mode for windows xp programs
I lost a driver software. How can i download and install it
You can download and install by yourself. I recommend you to use driver management program to download and install drivers for HP computer.
Free Download Install HP Driver on Your Windows 10 8 7 XP Vista
I have HP Deskjet 3420 printer, which I am using with my Compaq 7500 computer (window xp). Printer was purchased by me some 7 years back. I now want to use this printer with my dell laptop having windows 7...
There are no official drivers Win 7 avaliable for your AIO hp DJ 3420, but you can use an alternate compatible drivers for your model ie. hp DJ 3600 series. Read this link from hp Installing the Printer with an Alternate Driver in Windows 7 for a USB Cable Connection. Suggestions What have you tried to get Windows Update to work? I would suggest the following: Go to the Devices and Printers folder, Add a printer, Local Printer, LPt1, etc...when the list of printers comes up select Windows Update. After several minutes the list of printers should be updated and the Deskjet 3600 should be in the updated list. (Also keep in mind to look under 'HP' section of the driver (hp 3600) list and not 'Hewlett Packard'). Cancel the install the wizard & select "hp 3600" drivers to install on your Win 7 system. Hope it helps.
I am going to purchase hp z400 with xeon processor 4gb 500 gb nvidea 1gb quadro graphic card , please let me kno that can i install windows xp in it
Yes you should be able to install Windows XP on this computer system. However Windows XP Professional 64bit edition will be better as you will be running 4GB of RAM. If you use 32bit version it can only make use of 3.85GB of the 4GB installed.
If you can install Windows 7 Professional 64bit.
Take care!
damnor01
11helpful
5answers
Forgot my administrator password
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker
  • In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users.
I have the Installation programme for Family Tree Maker Version 11. I have just purchased a new computer with windows 7. Can FTM v11 be installed on Windows 7 and will it work O.K.?? The computer on...
Yes, it should run on Windows7, as I have done it some time ago. I have experienced a problem with the some printing options to PDF format, and I need to find a amyuni document converter to overcome this problem. Everythings else works and will not cause any problems to your existing files you have compiled
2answers
HP Photosmart C6280 not visible as printeroption though installed
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
3helpful
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
I have acer aspire laptop computer model 3692WLM1 windows media center edition I wish to purchase a HP DESKJET D4200 series printer will this be compatable for my laptop
Hey doodee,
According to information provided by the manufacturer, this model HP printer requires Windows 2000, Windows XP Home or Windows XP Professional in order to function. Apart from the obvious cosmetic changes and some extra added functionality, Windows XP Media Center Edition may be treated as basic Windows XP in many instances. As such, this printer should be compatible with your computer. Please keep in mind however, that you may need to perform driver and software updates in order to guarantee functionality.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
