Try
disabling startup programs. Go to Start > Run (search in Win 7) and type
MSConfig. In Startup tab, uncheck anything that you don't want Windows to
load automatically. It will make Windows boot faster and use less resources
while running. This just disables them in startup. Programs will still load,
but when only you initiate.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
As initial troubleshooting for this kind of problem you can follow the steps below:
- turn off the computer (make sure its completely off)
- press the power button and after 2 seconds tap F8 repeatedly until you see the advanced boot menu
- select the safemode (use the up and down arrow keys)
- press enter the let windows to load into safemode (hopefully it load)
- once successful click > start > all programs > accessories > system tools > system restore
- select a date a at least 4 or 5 days before this issue occur then just follow the on screen instructions
- computer will just automatically restart by itself back to windows (normal mode)
- if all else fails > reinstall the Operating System
The Olympus initialization [ib] software is loaded on the internal memory of the Olympus Sp-800uz camera. If you are using a SD / SDHC memorycard, take it out of the camera and reconnect the camera to the computer. If the camera does not pop-up a message to install the software, look with e.g. the windows explorer if there is any Removeable Device which corresponds with the memory of the camera. If there is, open it and look for a setup.exe program. If available, run it to install the software.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Yes there is an option that you can use to restore deleted files. Its called System Restore. You did not provide any information about your Windows version so the procedure may be a bit different.
From XP onwards the System Restore option is found: Start --> Programs --> Accessories --> System Tools --> System Restore. You can also access it through Help and Support by typing System Restore in search bar.
Try restoring your Windows to a date where it worked fine. Try the most recent date before you started experiencing this issue.
You should also check if the Magic Jack is working OK by plugging it another PC.
If System Restores fails, its better to backup your data on D: and reinstall Windows than to keep looking for a solution. This will save you time and frustration.
You need to boot in safe mode. Usually, this means to press F8 key repeatedly after turning on your computer. Once in safe mode, go into add/remove programs and remove the offending software. Then, reboot normally and you should be good to go.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
