I just purchased a 2007 VIP Vantage with an LST 3800 and it was experiencing similar problems. I noticed that the "UP" button didn't feel right when pushed, so I pulled it out of the dash and used a very small screwdriver to gently pry off the front bezel. There's a clip on each side that holds it in place, and it's fairly easy to remove. The rubber button pad had a tiny piece of plastic (it was the same material and color as the plastic in the bezel) between the bezel and the button pad that was causing the "UP" button to depress constantly. I put the button pad back into the bezel, snapped it back on and the depth sounder is working fine. Best of luck.
