Question about Viking DFUD142 Built-in Dishwasher
Viking Professional Dishwasher - dfud142 pump continues to run during drain cycle will not shut off when door is opened have to unplug to turn off
    Habit-Forming:
  • 153 Answers
More than likely the door saftey switch is broken, check your owners manual
Posted on May 12, 2011
SOURCE:
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
Viking Dishwasher won't start. All the lights continue blinking and it sounds as if a motor is continually running.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Viking 24 in. Professional Series VUD040...
Dishwasher keeps making suction sound though cleaning cycle is done
You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 21, 2011 | Viking 24 in. Professional Series VUD040...
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
Kitchenaid dishwasher won't drain someone opened door during cycle will this cause a problem
Opening the door wont matter. If you stop the cycle during a run it will always go into a drain. You might have a plugged drain line or burnt drain pump..
Apr 04, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Will not shut off
Hi this problem is the soil sensor. Basically the dishwasher will continue washing or add time to the wash if it thinks the dishes are still dirty. You will need to replace the soil sensor normally located on or by the drain pump. Mike
Mar 25, 2010 | Viking 24 in. Professional Series VUD040...
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
Cycle just continues with the pot symbol blinking
disconnect the hose and run it into a bucket, is it pumping freely?.
did you check the trap for a blockage?
You may have a leak in the pump housing area below the unit, this would cause the drain pump to run continually.
Jan 24, 2009 | Viking Designer Series DFUD041 (Premium)...
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher: upper tray rolls out everytime the door opens
put 2 small pieces of cardboard under the front legs until you get it where it wont roll out anymore. i had the came problem with my kenmore and it took care of it
Dec 28, 2008 | Viking DFUD142 Built-in Dishwasher
Viking DFUD142 Built-in Dishwasher Logo
369 people viewed this question
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Craig Butler
Craig Butler
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
