Cannot tune in to new samsung flat screen lost instruction book
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
0060 does not work with my model of Samsung
I found the code can vary according to the particular Sky Remote you have.
Look in the battery compartment for the version (it will say something like Rev 8R or Rev 9F)
For my model I found code 1647 worked with a Rev 9 remote but not with a Rev 8 remote
I found codes 1277, 1340 and 0646 worked with a Rev 8 remote but not with a Rev 9 remote
Other codes that worked with certain older models of remotes included 2079, 1177 and 0088
