Hi all..can u all help me to find out better pc cheating code for Stronghold Crusader ??its very hard for to find cause my office using proxy for all search about games/cheat code
I think I can help ya out. Try these......
At the Main Menu, press Shift + Alt + A to enable cheat mode. Now during gameplay, press any of the following:
[Alt]+[C] - All Missions
[Alt]+[K] - Free Building, No Resources Required
[Alt]+[X] - 100 Popularity and +100 Gold
Extra Peasants
Use the following trick to get a lot of extra Peasants (more than the campfire limit of 24) for buying whatever kind of forces you need from the Mercenary Post or Barracks. For example, put your Quarries (3 Peasants each) and Oxen to sleep. There will be that many more in your available amount when buying Swordsman or something else. Then just turn them back on when you are done and they will go back to work. This works if you do not want to wait until your Peasants fill up your campfire again, or you just need them immediately.
Conversation keys
The following is a list of things that will be said to an enemy after the corresponding key is pressed. Note: The spelling is the same way as it appears when done in the game.
[F1] - Oaf
[F2] - Varlet
[F3] - Fool
[F4] - Knave
[F5] - Peasant
[F6] - Help Help
[F7] - I win you loose
[F8] - Ill string you up
[F9] - You Damn Fool
[F10] - Mwahaha (Snort) haha
[Ctrl] + [F1] - Jack o napes!
[Ctrl] + [F2] - Buffoon
[Ctrl] + [F3] - Straw Pole
[Ctrl] + [F4] - Slubberdagollian
[Ctrl] + [F5] - Dastard
[Ctrl] + [F6] - Dolt
[Ctrl] + [F7] - Lollard
[Ctrl] + [F8] - Dotard
[Ctrl] + [F9] - Weasel turd
[Ctrl] + [F10] - Popinjay
Put Your Enemy Inside the Castle Using an Oxe
During playing this game, you maybe noticed that you can place your oxe teraten (oxe that use to carry rocks from a stone cury to stock pile), so you can use them to put your enemy keep inside the castle... Well how? Just put oxe in a way that they can stop the main gatehouse of the enemy castle and see the all instaltion of your enemy outside the castle will be demolish, this is best trick I use with saladin and wolf in many missions and they are unable to anything, but some time they destroy the oxe so you have to put them again.
These aren't really cheat but they may be helpful...I'll continue looking! Happy gaming....Later.....
-Jade
At main menu press shift + alt + a. Now in game press:
ALT + X ... Increases popularity by 100 and money by 1000.
ALT + C ... Cycle characters or unlocks all missions.
ALT + K ... Destroy enemy fortress.
ALT + Z ... Destroy selected enemy.
ALT + G ... Destroy main stronghold.
ALT + D ... Engage debug mode.
ALT + P ... Increase character's level.
ALT + F ... Upgrades and purchases become free.
ALT + S ... Time shift.
ALT + Q ... Time compression engaged.
ALT + Y ... All enemies on screen turn into **** sauce.
Cheat: Make your Own Taunts
First, go into C:\Program Files\Firefly Studios\Stronghold Crusader\fx\Speech or wherever you installed Crusader. You will find a bunch of sound files. You need a microphone to do this. To make this easier, put the list of files in alphabetical order. Now, scroll down to the file Insult1. Insult1=F1 and you get the idea. (You can double click to listen to the file). Now right click on Insult1 to bring up a menu. Look down the list and find, "record". Click on that and it should bring up the sound recorder. Press record, record what you want to say and click stop. Instead of going to file save, press the close box and it should come up with a message stating the directory of the file changed and it will ask you if you want to save the changes. Click yes. Now, you can go into the game, press F1 and you should hear your recording. You can also do this with any other file in the speech folder. Note: Be aware that you can't change the file back to its original voice unless you reinstall the game. This is based on Windows XP and it might not be the same on Windows 98. etc.
Hint: Hold Enemies Captive Inside Their Own Castles
Take a small building such as an Oxen Tether. Place 1 or 2 of them right outside the gatehouse(s) of your enemy's castle, but make sure their keep is enclosed first. Immediately put the Oxen Tethers to sleep. The ground troops will walk to the gatehouse to destroy them but they can't get through, so they just walk back to their spot. Your enemy's buildings outside of the castle will spontaneously crumble because the workers can't get back inside the castle. Also, the gatehouse(s) you blocked might spontaneously crumble after a while. Soon there will be no food and the peasants will leave the castle. The small army will be trapped inside their own walls awaiting your arrival. When your army is built up, you can just waltz over and wipe the whole castle off the map. (Note: Make sure there are no enemies outside of the castle, or else they will probably come and destroy your oxen tethers.
Hints
After finally beating the Crusader Trail challenge, here's some tactics that work well. See the above tactic for using an ox tether to block the enemies gate, but only use this on particularly difficult boards as you will not be able to collect stone.
Starting tactic, set game speed to lowest possible setting and spot your initial towers and crossbowmen. Put speed back after to preferred setting after you're set up. Defense is the first priority at all times. If you can defend then you can later go on offense.
Do not get locked into the concept of enclosing your castle. Quite often the best tactic is to surround your village area with towers filled with crossbowmen and ballistas. After filling the tower, delete the bottom step, enemy forces cannot get in and they won't try to tear it down either. You can always put it back in to send up reinforcements.
Leave an opening in your castle walls, heavily defend the opening. Attackers will gravitate to that opening, leaving the rest of your castle clear with walls that don't require defending. Make a death pass between two walls at that openeing, funnelling the enemy into a narrow place filled with swordsmen or pikemen.
Enemy towers that have seige engines can be taken out with the Assassin. Sneak him to the tower and let him kill the engineers. Use fire ballistas to burn the enemies farms, he will spend resources on replacing them instead of making new soldiers.
Here's some more.....Do ya need anythin' specific though?.....
Later,...... -Jade
Hiiiiiiiiiiiiiiiiiiiiiiiiiiiii
codes doesnot work
THe crusader codes do not work for some reason... i think its the shift + alt + a to enable cheats i have version 1.1 stronghold crusader
thecodes wont work what do u mean by main menu
i hv gt same problems code does nt work :(
how to get a gun
in the game
What are cheat codes for MLB 2k13 for the XBox 360?
Hay day cheat cheats codes
Battle nations
Want cheats for megabucks in meg cheats
Megabucks cheats
stuck on 125 cant get it
stuck on125
Its not letting me do the cheats
looking for cheat for battle pirates
Get coins
Pet rescue level 42
need to get cheats and codes to use to get better bingo's for all bingo room's! help been trying t win Victory in blitz tournament room. and as in slots.
all cheat codes
