Question about Jura Capresso 452.01 Coffee Maker
I think I need a new heating element for a Capresso 452. Are these available anywhere?
I had a problem with the coffee pot heater. You'll need to purchase a the proper temperature range thermistor, which is a temperature control device, and replace it. You'll also need special Torx bits with the hole in the end ( security-type screws ) to take the coffeemaker apart. Pretty easy job. Mine works great now
Posted on Mar 21, 2018
Coffee Maker manufacturers rarely sell individual parts for the machine aside from filters and whatnot. I recommend replacing it.
Posted on May 11, 2011
SOURCE:
Capresso c1300
Just a guess here but if you are not using soft water you may have a hard water scale coating on the sensor. The sensor is preventing the heating element from powering up because it thinks there is no water. Try filling the machine with vinegar for several hours (no more than overnight) This will dissolve hard water deposits and hopefully clear the sensor. (the sensor should be a simple continuity contact. If you can look inside and see a metal button and it is fouled clean it off.)
Aug 31, 2014 | Jura Capresso Coffee Makers & Espresso...
Repair Capresso CoffeeTEAM GS No heat Wont Pump Water
Check the elements. Unit heats water and forces that heated water out.
May 25, 2014 | Capresso CoffeeTEAM GS 10- cup Brewer and...
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
Capresso 452 coffee, looking for a manual
Here's an instruction video for a coffee maker like this.
Sep 27, 2010 | Jura Capresso 452.01 Coffee Maker
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
Bottom oven does not heat up fan works
The element is usually located at the rear of the oven compartment,behind a removeable cover, this is also where the fan is located.
Hope this helps.
Nov 29, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
I need a new manual for my Capresso 452 coffeegrinder/maker
Fantastic deal! I'm jealous. I'm on my second one and I paid about $200 each time! Here's the manual
http://www.capresso.com/pdf/inst_coffeeteam_s.pdf
Aug 17, 2008 | Jura Capresso 452.01 Coffee Maker
YLTE6234DQ2 - Dryer not heating up
Where is NA? Have you tried some websites for part resources? I found your part available at partstore.com. If you type in your model number, I found your element on page 15 as part #3387749. It lists for about $60. I hope this gives you a little more hope.
Jul 08, 2008 | Whirlpool LTE6234D Top Load Stacked...
Jura Capresso 452.01 Coffee Maker Logo
223 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
